Holiday Programs and Holiday Mode
 Posted: Friday May 2nd, 2008 03:22 pm
AdrianL
In the Comfort I training manual it states that Holiday programs will only start to run on the next day after setting to Holiday Mode.  Why is this?  If I go on holiday at midday, I would want my semi-random holiday programs to run eg that evening to switch lights on and off.  Is it the same in Comfort II?
Will the Time Programs run if just Holiday is set and not Mon-Sun and the time is after going into Holiday Mode or do they not run until after midnight also?
Incidentally, is there an equivalent to the Comfort I traning manual for Comfort II?  If not, where are these vital gems of information to be found?
Sorry to ask so many questions all at once but they are related.
Thanks and regards
Adrian.
 Posted: Saturday May 3rd, 2008 03:24 am
Adrian
I believe the Vacation (Holiday) Programs will run on the same day in Comfort II
For Time Programs if the day is a Holiday OR is the system is set to Vacation Mode,  the Time Program will run if  Holday is checked
We use the term Vacation Mode instead of Holiday Mode to avoid confusion between the Vaction Mode and the use of Holiday in Time Programs
There is not a single training manual, but if you go to http://www.cytech.biz/techinfo.html
you will find a lot of training material from Training slides, configuration, wiring guide etc
 Posted: Sunday May 4th, 2008 07:58 am
AdrianL
Thanks for your help.
A
 Current time is 03:18 am
