I am just about to place an order for my Comfort system. Comfort will be used as an Alarm and will also form part of a Home Automation system with CBUS.
The plan is to install Comfort in a central location and run all wiring back to this point
Comfort Gen 2 Untra II Panel
Backup Battery
KP04 Main Keypad
Door Phone
Phone Protection Board
CBUS Interface
Ethernet Module - UCM01/ETH
Now what is not obvious to me is how all the part physically fit together. Can all the above be located in the Main Panel?
Now thinking about zones
Initially I will need about 10 zones but this may increase over time if I put magnetic sensors on each window. So I will need to add extra zones.
The keypads and door station cannot be mounted inside the main panel
The Phone protection board, battery, UCM/CBUS and UCM/Ethernet can be mounted in the main enclosure
You also need the LEM01-M2 which mounts on top of the Comfort PCB
