I have to work on a older Comfort board, the label on the outside refers to a Minder Pro. The Legent on the board reads "PC01-001E". Its is not a split board like the Ultra II and it has the inputs on the bottom right and the outputs on the bottom left.
Q What board version is it? (Entry, Pro, Optimum, Ultra...)
Q What file system should be used? (17, 34)
Q Can I connect a 16 input LEM to it, and what would the product code be for this LEM
This is a MinderPro Mk 1, also known as Comfort I PRO. The file system is 18
You can connect a 16 zone LEM to it, part number is LEM03 or for Clipsal, 5350EXL16/0
