Keypad Anouncement
 Posted: Tuesday Feb 3rd, 2009 06:23 pm
miguardz
I have 8nos of Keypad installed.
During arm Night Mode i want to disable all keypad the anouncement of Night Mode and also disable the anouncement of Security Off when disarm from Night Mode?
Thanks.
Attachment: Peter Queries.ccl (Downloaded 11 times)
 Posted: Wednesday Feb 4th, 2009 02:45 am
HSLee
That is what i think, 4 step to do this. i also seek for admin advise
Step 1:
Attachment: Disable.JPG (Downloaded 74 times)
 Posted: Wednesday Feb 4th, 2009 02:47 am
HSLee
Step 2:
Attachment: Enable.JPG (Downloaded 76 times)
HSLee
Step 3:
Attachment: Disbale In night.JPG (Downloaded 77 times)
 Posted: Wednesday Feb 4th, 2009 02:50 am
HSLee
Step 4:
I hope can get other way by advanced member
Attachment: TimeProgram.JPG (Downloaded 76 times)
 Posted: Thursday Feb 5th, 2009 04:35 am
You have the right idea to use the Keypad broadcast disable and enable actions
HSLees program has a problem, because DisableInNight disables announcements for 10 seconds only, activated by Time Program at 10 PM. This is not necessarily when the system is being armed
PeterQueries.ccl file disables all announcements between 00:10 and 06:10. If this is what you want then it should work. However if you want to disable only the announcement of Night mode and Security off and allow other announcements then it does not do it as all announcements are disabled
To disable only the night and securityoff mode change announcements and allow other announcements, do a disable announcements in the Start Arm Response if the time is after 00:10 and before 0610 and use a timer to enable announcements in the Security off Response
 Current time is 05:52 pm
