Two Bell Boxes
 Posted: Friday Nov 27th, 2009 11:34 am
bryanajones
Hi, I'm still pawing my way through material, but hoped someone could help me out with a question.
How do I attach two bell boxes to a comfort II system? I have a comfort II main panel and a slave panel, both with LEM's.
As you can guess I'm just about to put it all together so any advice would be greatly appreciated.
Bryan
 Posted: Friday Nov 27th, 2009 11:48 am
Comfort's main Controller  can support 2 bellboxes provided there is a Battery (7AH 12V connected) to supply the extra current when the siren is on
The next firmware release (5.180) will allow the Slave to drive a belbox and Strobe so that will be better still
 Posted: Friday Nov 27th, 2009 03:36 pm
bryanajones
so just wire the two bell boxes and strobes to the one connector on the comfort main panel?
Does the slave panel already carry the bell and strobe connectors ready for the upgrade?
 Posted: Saturday Nov 28th, 2009 02:33 am
The answer is Yes to both questions
 Posted: Sunday Nov 29th, 2009 11:17 pm
bryanajones
So few words. So much wisdom ;-)
Thanks.
 Posted: Monday Nov 30th, 2009 01:09 pm
ndh
The bell boxes will have a wiring diagram for joining together and any strap settings. They don't just go in parallel to Comfort (from my experience)
Nigel
 Posted: Monday Nov 30th, 2009 01:20 pm
Good point. The bellboxes may have their own recommended way to connect when there is more than 1
 Posted: Monday Nov 30th, 2009 01:55 pm
bryanajones
ah, ok. I think the one's I have purchased have come with no documentation. I will try to id a make and model when I get home in the hope someone here could advise?
 Posted: Monday Nov 30th, 2009 11:11 pm
bryanajones
Got home and took a look. They're two CQR Cequra 2's.
I found this on wiring comfort to the Cequra. Does this look right?
Can someone comfirm that there's a 1k resistor between the +12v Hold Off and the Siren Trig -VE, and Strobe +VE and +12v Hold Off in this diagram?
There is a manual with the bell box that show's how to wire two. Thanks for the tip.
Attachment: bellbox.gif (Downloaded 40 times)
 Posted: Tuesday Dec 1st, 2009 02:39 am
The 1K resistors are to be added if the siren sounds when idle due to some leakage. If it does not then they are not needed. The value is not crfitical, you can probably use the 2.7K resistors in the EOL resistor pack
 Current time is 08:32 am
