Can someone explain partitioning and whether it's supported yet as I'd like to add to support in ComfortClient if it is at some stage.
In the latest Comfort Protocol manual you say:
PR - Partition Set
PC: PRNN
UCM: PRNN
NN is the partition for the user to be used when arming (0-3) This sets the UCM into the specified partition so that m! And M! Commands can arm the required partition and S? And other security queries can return the value for the partition. If the partition is not defined before the arming commands, then partition 0 is selected, or if the user is authorised only for 1 partition, then that partition is selected If the user is not authorised to arm or disarm in the partition then the request is rejected in the same way as a wrong sign in code is entered.
The partition set in this command is active until another partition is set.
PR without any parameters returns the current partition
Eg
PC PR
UCM PRNN
If NN = FF it means that there is no partitions defined in this system
Defined 19/4/2009
In the latest Installation manual (EngmanG2, Page 62) you say:
Can Comfort be Partitioned?
Comfort does not have any partitioning feature, where the system can be subdivided into two or more independent partitions, able to be armed and disarmed independently. However, it is possible to use the OMIT action (from v4.96) to bypass a group of zones (programmed as immediate in all modes) usually using a key switchor a stand-alone access control keypad to achieve a similar function. Refer to the Application Manual for the programming and setup.
Overall I'm confused and seeking clarification and references to more info?
