Posted: Saturday Jun 9th, 2012 09:18 am |
This may be also in earlier versions of Configurator but I've noticed in 3.5 beta.
Question is why "IR Transmit Codes" is under the "configuration" tree node whereas "IR Receive Codes" is under "Events"? The "IR Transmit Codes" section to me seems in the wrong place and seems to have nothing in common with the other nodes also in that section.
Posted: Saturday Jun 9th, 2012 09:41 am |
IR Transmit Codes has been in the Configuration category since CS-Xpress days
The idea is that the IR codes have to be configured before use
IR Receive Codes is in Events, which trigger Responses, so it is not appropriate for IR Transmit codes (which are not events) to be there as well.
In fact there is little relationship between IR Transmit codes and IR Receive codes besides the fact that they invoice IR signals
