Search by username
Comfort Home Automation/ Security System Forums > Comfort > Questions on Using Comfort > Keypad Announcement based on X10 RECEIVED command
 New Topic   Reply   Print
wexfordman
Status:  Offline
 Posted: Tuesday Jan 2nd, 2007 11:41 pm
 Quote  Reply
I am trying to set comfort up to announce a spoken phrase on receipt of an x10 command. For example
Receive A12 ON command and announce "water heating on"
I did the obvious, set up a response to announce "water heating on" on keypad and then set up this reponse to activate based on x10 A12 On, but it does not seem to be working.
I know x10 received codes are working as I have an autoarm command based on x10 receive a3on and this works.
Regards,
Eamon
adlim
Status:  Offline
 Posted: Wednesday Jan 3rd, 2007 12:08 am
 Quote  Reply
What is your Comfort firmware version?
Are you trying to use the "Announce Words" action? If so, this may not work for earlier Comfort versions.
wexfordman
Status:  Offline
 Posted: Wednesday Jan 3rd, 2007 12:28 am
 Quote  Reply
Main boards says 4.8.9 and UCM is 4.107. Are these the firmware versions ?
Sorry, I installed it almost 5 years ago, and have just started playing around with some of the more advanced features, so a bit rusty.
Regards,
Eamon
adlim
Status:  Offline
 Posted: Wednesday Jan 3rd, 2007 12:38 am
 Quote  Reply
The mainboard must be 4.223 or above for the "announce words" to work. Hence, that would probably explain the problem.
wexfordman
Status:  Offline
 Posted: Wednesday Jan 3rd, 2007 12:43 am
 Quote  Reply
Cheers, that explains it.
What is the process/cost of upgrading ?
Regards,
Eamon
 Current time is 02:17 pm
