| Author | Post |
Patrick Comfort Installers
| Posts: | 20 |
| Status: |
Posted: Tuesday Feb 27th, 2007 06:09 am |
| May I know how can I view camera through Comfort System?
ident Administrator
| Posts: | 286 |
| Status: |
Posted: Tuesday Feb 27th, 2007 12:59 pm |
The CWM (http://www.comfortforums.com/forum49/279.html )
or the Companion touchscreens (http://www.comfortforums.com/forum35/45.html) allow IP cameras like Axis to be viewed
You cannot view cameras using Comfort alone
on4cet Member
| Posts: | 21 |
| Status: |
Posted: Wednesday Feb 28th, 2007 08:48 am |
There are possibilities to watch camera's using comfort, if output from camera's is controlled by using eg. RLY01 or RLY02 relaisboards. The output can then be switched to a monitor, or time-lapse recorder etc...
I have a busch-wachter (PIR) on every side of the house (4), connected to a FINDER relay with 230Volt Coil, and 4 separate NC or NO contacts ...
1st contact for switching lights directly from the PIR
2nd contact for switching the Time-Lapse Recorder
3rd contact for switching the camera
4rd contact for switching an input of comfort to CLOSED state.
But, as said (and referred to in the manuals), this is a relais solution, by which you can view the source on a 3rd party device. Comfort is only involved for switching which camera you want to view !
Kind regards,
Bart
ndh Assisted Living
Posted: Saturday Mar 3rd, 2007 01:29 pm |
Thanks Bart. Just related to this - There is a 4 camera switching application in the Application Manual on http://www.cytech.biz - it was written in the pre Comfigurator days.
Nigel
 Current time is 12:22 pm | |
