Internal phone ring tone
 Posted: Sunday Mar 4th, 2018 01:55 pm
Ian
I have had a browse but can't find an answer to my question.
I have a Comfort II. When a door station doorbell is pushed the internal phone rings. I have a DECT system with caller ID, the phone shows 'External' when a doorbell is pushed.
I have two doorbells, one at tthe front of the house and one at the rear.
My question is; is there a way to identify which doorbell is pushed on the internal phone?
If there is it would be handy to set a different ring tone so I know which door to go to!
 Posted: Sunday Mar 4th, 2018 04:11 pm
The ring tone is determined by the phone, not by Comfort. The door station rings with a different timing than an external call
for 2 door stations, perhaps you can make a Response on the Disc Events > Doorbell Response
If DoorStationId = 1 Then
    Announce Door 1
Else
    Announce Door 2
End If
Can gurantee that it will work like that because it has not been tried
 Posted: Sunday Mar 4th, 2018 04:36 pm
Ian
Thanks for the reply - I'll have a play.
 Posted: Sunday Mar 4th, 2018 05:12 pm
Ian
It works - thank you.
Not what I could really do with as I can't hear the keypads all over the house, but its a start.
 Posted: Friday Sep 11th, 2020 01:54 pm
Ian
I noticed recently that this is no longer working. If I trigger the response manually from within Comfigurator it works, but it does not trigger if the doorbell is pressed.
It is still listed as the response to trigger under Miscellaneous Events\Doorbell Response.
 Posted: Saturday Sep 12th, 2020 04:54 am
The Doorbell response is still working. I have confirmed it a few moments ago.
Have you upgraded Comfigurator to the leatest 3.13.5?
 Posted: Saturday Sep 12th, 2020 06:30 am
Ian
I have.
 Posted: Saturday Sep 12th, 2020 07:56 am
Try writing to Comfort again
 Posted: Saturday Sep 12th, 2020 01:44 pm
Ian
That has sorted it out. Thank you.
 Current time is 05:40 pm
