Search by username
DM01 and Doorbell response
 New Topic   Reply   Print
Warby
Status:  Offline
 Posted: Wednesday Mar 26th, 2008 02:25 pm
 Quote  Reply
I am trying to get a Output to pulse when the Doorbell is pressed (DM01 and Fermax unit) i have tied the response to Misc. Events-Doorbell response. is this correct as it doesnt seem to be working!!
Status:  Offline
 Posted: Wednesday Mar 26th, 2008 02:58 pm
 Quote  Reply
Thats correct
It should work
See the comms in Monitor I/O and watch for the DB and OP messages
Also test with a test lamp on the output
Warby
Status:  Offline
 Posted: Wednesday Mar 26th, 2008 03:27 pm
 Quote  Reply
Ihave tried it using the monitor and it is say's
Rx: <STX>OP1301<CR>
Rx: <STX>OP1300<CR>
The response is
Output Output019 On
Do DoorBell_Off [Set Doorbell_Camera output Off] After 10 Seconds Using DoorBellCamera
And doorbell_Off is:
Output Output019 Off
It is the third output on the 1st slave board (all jumpers In for address) Firmware is 5.121
Warby
Status:  Offline
 Posted: Wednesday Mar 26th, 2008 03:36 pm
 Quote  Reply
Of course the Monitor is in Hex hence 13. will have to keep trying!
Status:  Offline
 Posted: Wednesday Mar 26th, 2008 03:41 pm
 Quote  Reply
You can see that Comfort is pulsing the outputs or at least trying to
The possibilities are that what is connected to the outputs is not turning on, or the outputs may be damaged in some way
The Monitor I/O is a useful tool in these situations
Warby
Status:  Offline
 Posted: Wednesday Mar 26th, 2008 04:01 pm
 Quote  Reply
It is very helpful. is there any documention on what the codes are. some are obvious but others not so?
Status:  Offline
 Posted: Thursday Mar 27th, 2008 01:18 am
 Quote  Reply
The codes are documented in the Serial  protocol document in the website
http://www.cytech.biz/techinfo.html
Scrolll down and look forr "Serial Command Set"
Status:  Offline
 Posted: Thursday Mar 27th, 2008 05:34 am
 Quote  Reply
Warby wrote: Ihave tried it using the monitor and it is say's
Rx: <STX>OP1301<CR>
Rx: <STX>OP1300<CR>
The response is
Output Output019 On
You have used a Timer to turn off the Output. This is OK but a batter way is to use the Pulse Output command
Pulse Output019 For 20
This pulses the Output for 1 second (units of 50 ms)
It saves you a timer!
 Current time is 08:23 am
