Cameras
 Posted: Wednesday Jan 2nd, 2013 06:18 pm
Has anyone got these working; I'm using with the latest 118 version?
I think the camera only shows if the checkbox is ticked but I'm finding it doesn't remember the ticked setting and you go back into config again only to find it un-ticked.
I also upgraded to the Pro version of the Cam software and finding that I have a mjpeg4 stream that shows fine in the CAM software itself but not in the same camera feed configured in the Android mobile app.
 Posted: Thursday Jan 3rd, 2013 08:05 am
I am not getting any problem with the camera selection
I select Pro version, and the app remembers it
There should be no difference because when you select Camera, the IPCam app is actually running
 Posted: Thursday Jan 3rd, 2013 09:10 am
OK it would help if I was running the correct version. I was using 1.83 that didn't have the checkboxes on that you mention. Got the correct version now and will try again.
 Posted: Thursday Jan 3rd, 2013 10:29 am
Look out for the new version in the next few days
 Posted: Thursday Jan 3rd, 2013 10:34 am
I downloaded the new version from PLAY in the end.
I have set to automatically update. Can I assume it'll retain my configuration settings or do these have to be setup again?
 Posted: Thursday Jan 3rd, 2013 10:36 am
Your configuration will not be affected
The download dialog when you download always says the settings will not be changed
 Current time is 09:19 pm
