Posted: Saturday Aug 15th, 2015 11:24 am |
Posts: | 5495 |
Comfort 2nd Generation Android Phone and Tablet apps will be released within the next week. Note that this requires ETH03 firmware 2.16 (download from http://www.cytech.biz/eth03_firmware.html ) and Comfort Server Manager 2.06 (included in Comfigurator 3.10.4)
Note: For this update, the older version must be uninstalled before installing the new version 1.6. This is because of differences in the data structure due to the extra port which cannot be updated. After uninstalling the older version, the new version can be installed
The new feature will be the ability to select the port for Local or Remote (Internet) connection from the log in screen
You can select Local1, Local2, Remote1, Remote2 port for connection.
ETH03 2.16 allows 2 ports for connection eg Ports 1001 and 1002
This allows 2 applications to connect to Comfort eg Android, iOS app or Comfigurator at the same time.
However only 1 connection can be made at one time to one port. If the port is busy, the application can connect to the other port.
The new version of the app allows the user to see which port is free.
Check one of the boxes Local1 or Local2. If the port is free the app will show "Connected" as in the above screenshot. The Login button will be visible.
If the port is busy, it will show "Connecting..." and the Login button is grayed out. Switch to the other local port to connect.
For the 2 Remote ports, there should be 2 ports forwarded on the router for connection by Internet
The Setup screen is shown
In the above example, 2 local ports 1001 and 1002 and 2 remote ports 8084 and 8085 are entered.
The 2 local ports must be set-up using Comfort Server Manager
2 2 remote ports must be set up by Porty Forwarding on the router
If any of the local or remote ports are not set up, the ports will be grayed out and cannot be selected on the login screen
Download ETH03 firmware from http://www.cytech.biz/eth03_firmware.html
Comfort Server Manager 2.06 is included in Comfigurator 3.10.4
Posted: Saturday Aug 15th, 2015 11:47 am |
Posts: | 5495 |
The screenshots for the Comfort Tablet app 1.6 are shown below
Local Port 1 is busy
Local Port 2 is Connected
Posted: Tuesday Aug 18th, 2015 11:43 am |
Posts: | 1200 |
Please upgrade your android app to 1.6 from the Google Play Store
Posted: Tuesday Aug 18th, 2015 01:26 pm |
Posts: | 1200 |
If you have problems in not being able to see the 2 ports or select them please take note of the warning above.
This is necessary because of the changes in data structure for the 2 ports.
Note: For this update, the older version must be uninstalled before installing the new version 1.6. This is because of differences in the data structure due to the extra port which cannot be updated. After uninstalling the older version, the new version can be installedLast edited on Tuesday Aug 18th, 2015 02:41 pm by
Posted: Saturday Aug 22nd, 2015 08:31 am |
Posts: | 5495 |
If the phone or tablet is set to auto-update applications, then this will result in the new version upgrading the previous version
This will cause a problem as the old data needs to be deleted.
In this case please delete the app from your device and re-install it again
Apologies for this problem
Posted: Wednesday Aug 26th, 2015 07:41 am |
bagushandhoko
Posts: | 91 |
For android user interface, is it only "on off " function has button icon ? Could other function is given "button" icon . eg : Circle Button for represent push button switch function ?
Posted: Wednesday Aug 26th, 2015 04:50 pm |
Posted: Wednesday Aug 26th, 2015 06:21 pm |
Posted: Thursday Aug 27th, 2015 03:47 pm |
Posts: | 5495 |
No we do not have push button
Posted: Saturday Mar 12th, 2016 01:40 am |
Swiss-Toni
I know this maybe a big ask, but is their any chance of developing a widget for Android, (Unfortunatly I do not have the skill set to build apps) With a sizeable widget feature made for a tablet it could be made to use the whole screen so that it is ready on demand rather than just having to log on to the icon.
I dare say this should be in the wishlist request section. The set up could mean a tablet would be ready with the display set permanent to basic non security features as the android app does now, this would make it far more conveniant and more user freindly
It's just food for thought!
Posted: Sunday Mar 13th, 2016 06:27 am |
Posts: | 5495 |
Thanks for the suggestion. It wil be considered
Posted: Wednesday Mar 30th, 2016 08:53 am |
aheadall
Posts: | 1 |
Can I put the graphic map and icon associated with zones into the App. And they blinking when alarm occur ?
Posted: Wednesday Mar 30th, 2016 03:42 pm |
Posts: | 5495 |
No, you cannot add your own graphics
The app is designed to be simple, requiring no special programmming
Posted: Monday Apr 4th, 2016 05:07 am |
dcrera
Any chances of a MS windows App via Ethernet cable?
Posted: Monday Apr 4th, 2016 05:42 am |
Posts: | 5495 |
Not specifically Windows but we are looking at a browser based webserver
