Posted: Saturday Sep 10th, 2011 10:41 pm |
rodime
I have comfort firmware 5.211 and UCM/Ethernet 5.212 and UCM/CBUS 5.208.
I was waiting for the latest version of Comfort firmware which allows UCM or Comfort firmware updates direct from Comfigurator. I was hoping therefore not to need to have to get hold of another UCM, however it seems I will still need one to do the initial upgrade to get the UCM to version 6.008.
Are the following steps correct-
1. Upgrade Comfort firmware to 6.005 using the programming cable from the existing UCM Ethernet 5.212.
2. Obtain a 2nd UCM to update the firmware of UCM Ethernet from 5.212 to 6.008
3. Future firmware upgrades can then be done direct from Comfigurator to either Comfort or UCM with no cable or 2nd UCM required.
Questions
1. Is above correct, or is there another way without needing a 2nd UCM?
2. Once the updates are done, can you therefore in future update the Comfort and/or UCM firmware remotely from an internet connection, without having to open the comfort system?
Posted: Sunday Sep 11th, 2011 02:13 am |
Yes you will still need to upgrade your Comfort and UCM firmware 1 last time using the programming cable
Once the firmware is 6.xxx, you can upgrade the UCM/Ethernet by direct connect, and the UCM/CBus and Comfort via the Coomfort Bus, using Comfigurator 3.3.1 or above
The procedures are at http://www.comfortforums.com/forum92/2409.html
With a UCM/Ethernet and a port forwarding router configuration you will be able to upgrade the firmware from the Internet. However as protection you will have to press F0 on the keypad to allow firmare upgrade
I am sure someone will be able to help you upgrade your UCM
Posted: Sunday Sep 11th, 2011 07:44 pm |
rodime
OK, thanks.
Anyone out there have a UCM they don't mind lending me a for a day?
Posted: Wednesday Sep 21st, 2011 10:40 am |
ndh
Add your location to your profile? (e.g. Town/County/Country)
Posted: Wednesday Sep 21st, 2011 10:57 am |
Posted: Monday Oct 10th, 2011 05:27 pm |
ndh
If you have not had an offer yet send me personal message. My son works in Surbiton on Saturdays ...
Nigel
Posted: Monday Oct 10th, 2011 08:23 pm |
Posts: | 788 |
Our you could send it over to us and we will update it for you!
Posted: Monday Oct 17th, 2011 08:18 pm |
rodime
Thanks for the offer Nigel. All sorted now, I sent it off to Andy who did the update for me. - Thanks again Andy
Posted: Thursday Oct 17th, 2013 05:35 am |
daniedb
Posts: | 17 |
I have a similar problem, but do not have a UCM upgrade cable.
Where can one order such a cable from?
Thank you
Posted: Thursday Oct 17th, 2013 05:48 am |
Posts: | 788 |
Send me you address and i will send one i the post FOC
Posted: Thursday Oct 17th, 2013 07:06 am |
I think you are in South Africa?
It may be a bit far for Home to post
Have your contacted to RSA distributor/
Home IQ
34 Cumberland Ave
Vandia Grove
2194 Gauteng
Contact: Brad Snaith
Tel: +2711 462 0964
Email: info@homeiq.co.za
Website: http://www.homeiq.co.za
Which UCM do you have?
Only UCm with firmware 5.100 and above can be used to upgrade other firmware
If you have older firmware, then you may need another UCM
If you have the old model UCM01 then you cannot use this to upgrade and it also cannot be upgraded
Your UCM should look like these
http://www.cytech.biz/pc_interfaces.html
Posted: Thursday Oct 17th, 2013 07:49 am |
daniedb
Posts: | 17 |
Thank you for the response.
I have the following UCM (Type 10) ver 6.012. This one is fine, I also have the following to be upgraded.
UCM (CBUS) - Ver 5.132
UCM (GSM) - Ver 5.133
Comfort II Ultra motherboard - Ver 5.183
I have tried the contact you have given, but no response yet.
Thank you
Danie de Bruin
Posted: Thursday Oct 17th, 2013 09:39 am |
The UCM programming cable should be supplied with every UCM
Perhaps it is still in the box?
You can upgrade your UCM to version 7 without the UCM programming cable, see
http://www.comfortforums.com/forum20/3543.html
But you need the programming cable to upgrade your 2 UCMs and Comfort. After that you do not need the programming cable to upgrade firmware again
Posted: Thursday Oct 17th, 2013 09:53 am |
daniedb
Posts: | 17 |
Thank you. I have not received such a cable when the install was done and the installer cannot help me. That is why I am enquiring if one can buy this cable separately.
Is it possible to order this directly from the manufacturer?
Thank you
Danie de Bruin
Posted: Thursday Oct 17th, 2013 09:58 am |
we can send you one
Please send your name, address to support@cytech.biz
Posted: Thursday Oct 17th, 2013 11:16 am |
daniedb
Posts: | 17 |
I have send an e-mail as requested. I appreciate the support.
Thank you
Danie de Bruin
Posted: Monday Dec 16th, 2013 07:26 am |
17th Post |
daniedb
Posts: | 17 |
I have a UCM/CBUS 5.132 and trying to upgrade the firmware to 6.011. I am doing this using an upgrade cable, but continue to get an upgrade error.
Is there perhaps a known problem with this specific version (5.132) of CBUS/UCM.
Are there other options perhaps?
Thank you
Danie de Bruin
Posted: Monday Dec 16th, 2013 07:46 am |
18th Post |
hendy
Posts: | 221 |
What is the upgrade error message? "DUT is not connected" ?
If so, did you shunt the PP2 pins on the UCM/Cbus?
The PP2 (2-pin header) needs to be shunted during the firmware upgrade.
