Virtual Outputs
 Posted: Sunday Feb 24th, 2013 02:38 pm
jjsg
Hello;
After upgrade my comfort to version ULT 7.015 and Configurator to V3.6.5
I can't work with virtual Outputs,
Waht's wrong?
BR:
José Gonçalves
Attachment: Vo 1.jpg (Downloaded 33 times)
 Posted: Monday Feb 25th, 2013 01:53 am
Which version for firmware did you upgrade from
What did you do with the virtual outputs, as there is not much use for them?
Can you send the cclx file to support@cytech.biz
 Posted: Wednesday Feb 27th, 2013 12:51 am
Comfigurator 3.6 does not support Virtual Outputs anymore although the action code is still supported in firmware
you can use Edit Action Codes to manually add
136, virtual output no, 0 for 0ff, 1 for on
eg 136,10,1 means Virtual Output 16 On
136,2,0 means virtual Output 2 Off
The concept of Virtual Outputs is redundant because the action Send RS232 is able to send any text or numeric string to any UCM
 Current time is 12:41 pm
