Comfig 3.8.2 firmware upgrade
 Posted: Tuesday Mar 4th, 2014 01:31 am
I was using comfig 3.8.2 to do some product upgrading prior to installation.
OK with UCM's and KT03 etc.
HOWEVER i wnt to upgrade the main CPU to the latest version - the upgrade was in progress and the laptop went into screen save. When i reserected it a few seconds later the % bar had dissapeared and the LED on UCM and main board had locked on.
The software said CPU was now 7.000
I powered down and now cannot re-connect at all ! solid green LED on main board ( same after reset). KT03 screens all ok but no reaction to anything...
HELP !
 Posted: Tuesday Mar 4th, 2014 01:34 am
EVEN WORSE
Just switched everything off at the mains, powered back on and main board made a few clicking noises and is now dead !
 Posted: Tuesday Mar 4th, 2014 06:20 am
The one thing you should not do when the firmware upgrade fails for any reason is to reset the Comfort or power off, see http://www.comfortforums.com/forum92/3400.html and http://www.comfortforums.com/forum111/2967.html
You should repeat the firmware upgrade immedialtely. It should complete without any problems
If the power is cycled or system is reset, you have to do the firmware upgrade using a UCM and the firmware upgrade cable, see http://www.comfortforums.com/forum4/1216.html
 Posted: Tuesday Mar 4th, 2014 01:40 pm
OK
I have re-programmed via cable and have result BUT....
- Powering the board up with the 7.000 firmware still caused a click and buzz sound on power up- NO LED's were visible.
After upgrading by cable I left the CPU connected ( still no LED's) and did a scan but the UCM was not recognised. I could NOT scan the main CPU.
I powered the CPU down and re-powered and hey presto green LED and i can now scan etc. All looks OK.
Hope this helps.
 Posted: Tuesday Mar 4th, 2014 01:48 pm
After completing the firmware upgrade by cable and removing the cable you just need to reset the systemOtherwise it will not know you have removed the firmware upgrading cable
 Current time is 08:15 pm
