Posted: Tuesday Mar 2nd, 2021 09:26 pm |
caravanboy
Posts: | 130 |
My ETH03 has 2 ports configured 1001 and 1002.
I usually use the first one for Comfigurator and I've recently been testing a separate Comfort->MQTT Bridge connecting to the port too.
I had forgotten there was a second port and I've now proved I can connect both at the same time - e.g. Comfigurator to 1001, and my MQTTBridge to 1002.
However, my bridge also seems to see messages to/from Comfigurator, so I assume the Comfort connection is more of a bus than an individual point-to-point connection?
So... can I assume it would NOT be safe to use Comfigurator to do any programming if my module was also connected and active? i.e. I should only have 1 device connected to Comfort via ETH03 when programming?
Posted: Wednesday Mar 3rd, 2021 12:42 am |
However, my bridge also seems to see messages to/from Comfigurator, so I assume the Comfort connection is more of a bus than an individual point-to-point connection? So..
Your 3nd port will see messages to /from Comfort, not Comfigurator
It is safe to use Cmfigurator. However you cannot use Comfigurator to read and write to Comfort at the same time as that will block the 2nd port
Posted: Wednesday Mar 3rd, 2021 07:44 am |
Posted: Wednesday Mar 3rd, 2021 07:45 am |
Ian
Posts: | 249 |
I use both ports in the way described and have been doing for some time. It works well. I recently moved to MQTT and have been impressed with how well it works.
Posted: Wednesday Mar 3rd, 2021 07:58 am |
what MQTT bridge are you two using? We would like to test it
Posted: Wednesday Mar 3rd, 2021 08:08 am |
Ian
Posts: | 249 |
I have paho; https://pypi.org/project/paho-mqtt/ I then use a pyhon script that reads Comfort. It was created by a member on here - I think Koochyrat may be his/her name. Last edited on Wednesday Mar 3rd, 2021 11:52 am by Ian
Posted: Wednesday Mar 3rd, 2021 08:09 am |
caravanboy
Posts: | 130 |
I'm using this one that is described on another thread on this forum: https://github.com/koochyrat/comfort2
The quirk I am having is without timeouts though. When I just have my MQTT bridge connected to Comfort on the 2nd port it does not seem to timeout. However, when I'm using the 1st port it times out at random intervals, which is annoying.
Both ports are set in ETHO03 to timeout after 2 mins. The MQTT bridge uses the "cc" echo command every 30 seconds to avoid timeouts, so I do not understand why port 1 would still regularly lose connection every few mins.
Posted: Wednesday Mar 3rd, 2021 11:22 am |
caravanboy
Posts: | 130 |
slychiu - re. my timeout comments in the message above. Any thoughts on that? I've switched the MQTT bridge back to port 1 this morning check and it has started doing the frequent timeouts again. When connected to port 2 it is rock solid and never seems to time out. Is this an expected difference between the ports even though Comfort Server Manager claims they are both set at 2 minute timeouts? I'm on firmware 2.23 on ETH03
Do you see that behaviour too, Ian?
Posted: Wednesday Mar 3rd, 2021 12:06 pm |
Ian
Posts: | 249 |
I'm not. I do recall that I reset the timeout for another reason. At the moment Comfort Server Manager is not seeing the ETH03 0 don't know why - so I can't look. I think I may have set it to 0, meaning don't timeout. I suspect slychui will advise.
Posted: Thursday Mar 4th, 2021 01:55 am |
The time out should also work on Port 1.
Could it be that you did a write or read to comfort. This would have disconnected the other port
Posted: Thursday Mar 4th, 2021 07:40 am |
caravanboy
Posts: | 130 |
No, Comfigurator is not running. The only thing ever connecting to Comfort in my solution is Comfigurator or the MQTT Bridge.
The timeout does seem to be related to activity from Comfort. After we go to bed (i.e. no PIR movement) then the MQTT bridge stays connected all night on Port 1 with no timeouts at all. As soon as we start moving around zones again then the timeouts start happen.
When there is plenty of normal activity the connections seem to be at exactly 2 minutes to the second. When there are gaps in zone activity then the timeout takes long. That is VERY strange. Even yesterday when I was home alone sat working in a room with a single PIR the timeouts still happened fairly often.
I'll download my log this evening and see if I can spot any patterns.
I will also swap back to port 2 and run it today and check that it definitely does not timeout on that port.
Posted: Thursday Mar 4th, 2021 07:53 am |
Ian
Posts: | 249 |
I've had my MQTT running on both ports, I swapped for another reason, with no issues.
Posted: Thursday Mar 4th, 2021 08:01 am |
caravanboy
Posts: | 130 |
Hmm, well, in the last 10 mins port 2 has not timed out so far yet, which would be unusual for port 1.
Maybe this is a difference in behaviour between different firmwares, Ian - what versions do you have?
I can see in the MQTT bridge log that I receive an unsolicited "LU00" just before the bridge reports a timeout, so Comfort seemed to be deliberately choosing to send the LU00 for some reason, but only from Port 1.
Posted: Thursday Mar 4th, 2021 11:12 am |
Posted: Thursday Mar 4th, 2021 12:45 pm |
caravanboy
Posts: | 130 |
Hmm. My mainboard is 7.116 and the ETH03's UCM is 7.098
Are there any known issues with differences in timeout behaviour between firmwares slychiu?
Port 2 has also been connected fine for the last 5 hours with no timeout and plenty of zone activity.
Posted: Thursday Mar 4th, 2021 02:41 pm |
Ian
Posts: | 249 |
Any reason why you shouldn't update?
Posted: Thursday Mar 4th, 2021 02:54 pm |
17th Post |
caravanboy
Posts: | 130 |
I did consider updating a few weeks ago but when I read some of the firmware release notes I think there was something that mildly concerned me, I forget what. I work in IT so I shouldn't be averse to updates but they always make me a little more nervous on hardware, especially when everything else all seems okay Although we've never resolved my long-running issue with why the SMS messages get delayed during power failures and I do recall seeing the GSM4 firmware mentioned SMS buffer increases. Anyway, I'm digressing... no real reason, so I may just refresh my memory on how to do one (been a couple of years I think) and then bit the bullet and update them all.
I'll come back here and post an update in a few days to say if it makes any difference
Posted: Friday Mar 5th, 2021 12:53 am |
18th Post |
try setting the time out to 0 for testing if it still logs out
Posted: Tuesday Mar 9th, 2021 04:31 pm |
19th Post |
caravanboy
Posts: | 130 |
Hi Slychiu - I set timeout to zero on port 1001. It then behaves same as port 1002 and never times out.
Setting it back to "02" (which I assume is minutes and not seconds, as the UI doesn't say) means port 1001 has now gone back to timing out again every few mins.
I have not yet had time to try the firmware upgrades.
Does the timeout 0 behaviour give you any clues/thoughts?
Posted: Wednesday Mar 10th, 2021 12:31 am |
20th Post |
02 means 2 minutes. That should time out every 2 minutes so it looks like it is workng
Anyway please upgrade to the latest firmware, as we should not be troubleshooting using old firmware which may have other bugs which have been fixed
Current time is 05:08 pm | Page: 1 2 |
