Posted: Thursday Nov 14th, 2019 01:10 pm |
Posts: | 5766 |
OP04 is an Output Submodule with 4 Relays which plugs in to CM9001 in place of OP01 (with 8 open-collector Outputs).
This connects 4 relays direct to Outputs 1 to 4 of CM9001. Outputs 5 to 8 are not available when OP04 is plugged in
Posted: Wednesday Nov 20th, 2019 04:26 pm |
Swiss-Toni
With the OPO1 if the board goes you would just replace the board, if this goes you have to replace the board or is that a resetable fuse set into it, also what what is the voltage max capacity.
Posted: Thursday Nov 21st, 2019 02:15 am |
Posts: | 5766 |
If this fails you also replace the submodule just line OP03 and OP01
It is less likely to fail than OP03 or OP01 because the relays have 5000V isolation/breakdown volatge.
In OP01 and OP03 the outputs are open collector transistor outputs and are more easily damaged
