Upgrade UCM/Eth to Eth2
 Moderated by: hendy
 Posted: Monday Oct 14th, 2013 10:37 am
ninotorres
My ETh module seems to have died :-(
I can't reach it and all Leds are off on the Eth Module. All Leds on UCM board seem ok and working. Network connectivity is ok as proved by another device connected to the same cable. Anyone saw this before?
Assuming that the UCM board is OK and thinking about replacing the module if it is faulty, I would like to know if I can simply replace the ETH1 module with a new ETH2 on the same UCM.
Is it "plug-play" or must I use a soldering iron somewhere?
Thanks.
 Posted: Monday Oct 14th, 2013 11:22 am
Yes you can. You'll probably want to go for the new Eth03 too when it's released?
 Current time is 05:01 pm
