UCM/KNX power failure alarm
 Posted: Monday Dec 6th, 2010 10:50 am
ekarak
I would like to know when the KNX bus voltage (29V) is down either due to power supply malfunction or other cause (i.e. short-circuit). I think when one uses KNX virtual zones it would be something like zone trouble, or there could be a seperate alarm type for KNX bus voltage failure.
Elias
 Posted: Monday Dec 6th, 2010 11:07 am
No, there is no indication of power failure on the KNX to Comfort.
The KNX bus is not suitable for high security applications as that is not what it was designed for.
If security is very important, alarm PIRs with power supply from Comfort should be used
 Current time is 03:39 am
