Invert zone open/closed sent to KNX
 Posted: Thursday Feb 13th, 2020 01:41 pm
TheMax74
Hi Chiu
currently, when mapping comfort zones to KNX Group Addresses, 0 = Off, 1 = On.
Is it possible, to allow the user to invert the values sent to the bus: 0 = On, 1 = Off ?
Massimo
 Posted: Friday Feb 14th, 2020 01:35 am
If you use Physical zone mapping to KNX you cannot change the meaning of 0 for off, 1 for on. That is the universal meaning of 0 and 1. One would not normally associate 0 for on and 1 for on
However if you use Zone Responses to send KNX telegrams then you are free to send any KNX telegram for each zone on and zone off event
 Posted: Friday Feb 14th, 2020 05:33 am
TheMax74
Hello Chiu.
Good idea. Thank you.
With Voice Assistants like Alexa, Siri, Google home, the mapping must be 0 = On, 1 = Off.
Bye.
 Posted: Friday Feb 14th, 2020 05:43 am
I think someone should tell them that they have done it wrongnobody things 0 for on 1 for off
 Posted: Friday Feb 14th, 2020 12:57 pm
TheMax74
Hi Chiu.
I spoke with an Apple Homekit developer about that.
It makes somewhat sense.
Contact Sensor device type (in all 3 voice assistants) bring the zone value as is.
If the contact is closed, the zone is INACTIVE (like in Comfort), therefore for these 3 assistants, the zone is secure and they represent that with "Off" (that means "no problems")
If the contact is open, the zone goes to ACTIVE, therefore for these 3 assistants, the zone is unsecure and they represent that with "ON" (that means "hey, there is a problem here").
For now, i solved by unmapping Zones from KNX/UCM and by using the UCM/PI to do an inversion of the zone values, but you'll find out having same issues like this one, as soon as some Comfort installer will try to link KNX zones with the voice assistants.
 Posted: Saturday Feb 15th, 2020 01:10 am
Comfort zone types can be Normally Open or Normally Off
If you want contact Closed to be Off and Open to be On, the you select a Normally Closed Zone Type eg Switch Normally Closed
Hence yoiu do not need to make amyu special zone responses, just map input to KNX dorectly
 Current time is 04:28 am
