cat6
 Posted: Sunday Jan 1st, 2012 04:42 pm
polaroid
I'm flooding our renovation with cat6.
Is cat6 good for connecting my detectors/sensors/keypads etc... to Comfort?
thanks!
 Posted: Sunday Jan 1st, 2012 10:55 pm
schford
If your using one type of cable make sure its shielded so your voice works A ok!
 Posted: Monday Jan 2nd, 2012 01:15 am
Just be careful when terminating the cables if they are single core instead of multistranded as it is easy to nick or break the wires. I think CAT6 multistranded is also available which is more flexible and does not break so easily
 Posted: Monday Jan 2nd, 2012 06:33 am
bs85
Currently flooding my new house with cat6 for data.
But still using cat5e for the the alarm panels keypads and alarm cable for the sensors as it is so much easier to work with and is cheaper.
Have you tried to get cat6 into a PIR?
 Posted: Tuesday Jan 3rd, 2012 10:21 am
polaroid
Thanks for this guys!
I'll research your suggestions!
 Posted: Tuesday Jan 3rd, 2012 01:46 pm
Any of the above will do - the CAT6 is more bulky and total overkill.
As already mentioned always use screened for voice /mic.
We have installed hundreds of Comfort panels and always used to use CAT5. However rarely if ever did the other cores get used so we now simply install alarm cable which is actually so much easier to 'pull'. Also when terminating the cables at the comfort unit using alarm cable means that you can make an even neater installation.
Of course alarm cable is available in white or brown 4, 6, 8,or 12 core and is significantly more cost effective.
 Posted: Wednesday Jan 4th, 2012 12:58 am
We have installed hundreds of Comfort panels and always used to use CAT5. However rarely if ever did the other cores get used so we now simply install alarm cable which is actually so much easier to 'pull'. Also when terminating the cables at the comfort unit using alarm cable means that you can make an even neater installation. Of course alarm cable is available in white or brown 4, 6, 8,or 12 core and is significantly more cost effective.
Do you mean to say you use Alarm cable for security sensors and shelded CAT5 for keypads?
 Posted: Wednesday Jan 4th, 2012 06:08 am
To add to the last post - you can also purchase shielded 4,6,8,12 core alarm cable in white or brown.
So in response to ident we now use alarm cable for most applications.
 Posted: Wednesday Jan 4th, 2012 07:03 am
Ok but be careful when you use  alarm cable for keypads, UCMs etc for long distances
The RS485 Comfort bus achieves longer distance for twisted pair but alarm cable is not twisted
 Posted: Wednesday Jan 4th, 2012 08:39 am
polaroid
ident...
So if I have sensors that require a long distance cable di I use stranded cat5?
 Posted: Wednesday Jan 4th, 2012 08:53 am
Stranded CAT5 is easier to handle than solid core CAT5 for alarm sensors. generally there is no problem with distance for alarm cables as long as the cable resistance in tens of ohms
 Posted: Sunday Jan 8th, 2012 08:53 am
What do you call long?
 Posted: Sunday Jan 8th, 2012 01:29 pm
13th Post
We cannot  define what is long
The RS485 standard specifies twisted cable, to prevent noise interference. It does not say how much the performance would be degraded by if nontwisted cable is used
It depends on many factors like distance from interfering signals like mains cables etc so it cannot be guaranteed. If your alarm cable is shielded that does improve the situation, so you wil have to make a judgement  based on experience
 Current time is 09:27 am
