| Posted: Saturday Jan 14th, 2012 06:24 pm |
polaroid
| Posts: | 12 |
| Status: |
I'm about to run my alarm cable around the property (whitch is under renovation)
I've been looking into differnt types of sensors etc...
Is there a certain type of sensor I should use?
I've been reading about open and cloesd, and sensors that would need resistors added to the wiring!
I need to find out and decide what kind of sensors before I take the wires to theeir destination!
I know it's a very basic subject for some of you, but I need to get my basics right!!
Thanks guys!
| Posted: Saturday Jan 14th, 2012 08:52 pm |
schford
| Posts: | 184 |
| Status: |
You can tell comfort whether you deploy normally open or closed and whether you use resistors to detect tampering or not, just make sure you get the right wiring in place!!
| Posted: Saturday Jan 14th, 2012 10:32 pm |
polaroid
| Posts: | 12 |
| Status: |
I think I know what kind of sensors and detectors I need and where!
Can you recommend a supplier or makes/models?
Please excuse my little knowledge,!
| Posted: Sunday Jan 15th, 2012 02:28 am |
| Posts: | 1617 |
| Status: |
There are many supplliers of alarm sensors and accessories, like PIRs, Magnetic door/window contacts, smoke sensors etc for example http://www.hunters-wholesalers.co.uk/burglar-intruder-alarm-systems-c-42.html?osCsid=a11e5bf470e3c6e10c4e32422d4c20d0
All alarm sensors have an open/close reed relay contact which can be connected to Comfort Inputs.
Some sensors require 12V power eg PIRs, smoke and heat sensors. The 12V supply should be taken from Comfort 12V/COM
Hence for a non-powered sensor eg door/window contacts, 2 wires and enough while for powered sensors you need 4 wires
Standard alarm cable comes in 2 pair, 3 pair or 4 pair. It is recommended to use 4 pairs so as to have spare cables as the cost difference is not a lot
| Posted: Sunday Jan 15th, 2012 05:59 pm |
polaroid
| Posts: | 12 |
| Status: |
Great guys, thank you very much!
Can't wait to start building my system!
No doubt I'll have some more simple questions!!
