End Of Line Resistors
 Posted: Friday Aug 10th, 2007 02:25 am
salizam
Hello again,
What is actually EOL, what is the purpose and how does it work. And how to wired it.
Thanks,
Regard
salizam
 Posted: Friday Aug 10th, 2007 06:10 am
adlim
EOL means End of Line Resistor These are the resistor values which must be connected to the sensor contact when the Zone shunts are set to the End of Line position, ie away from the terminal block. End of Line Resistors allow Comfort to raise a Trouble alarm when the alarm wiring is cut
You can refer to the installation manual for information on how to connect the resistors.
 Posted: Saturday Sep 4th, 2010 08:01 am
Comfort's End of Line Resistor values are 2.7K ohms in series with the contact and 4.7 K ohms in parallel with the contact.
The 2.7K ohms value can be substituted with 2.2 Kohms without any problem.
The values 2.2 Kohm and 4.7Kohm are commonly used in the UK and some other countries. If Comfort is bneing installed to replace another alarm system with these values, then the EOL resistors need not be changed
 Posted: Tuesday May 31st, 2011 01:16 pm
Zone Trouble means that the zone shunts are inserted in the "Double End of Line Position", but there are NO End-Of Line Resistors connected to the Zone Input.
The Zone shunts are 3 pin headers  marked JZ1 to JZ8 near the terminal block for each zone
Put the shunt Closer to the terminal block for NO End of Line Resistor, and AWAY from the Terminal Block for DOUBLE End of Line Resistors
If you do not install 2 End of line Resistors, then put the shunt  in the position closer to the terminal block
The Installation Manual which explains how to connect zones can be downloaded from http://www.cytech.biz/installation_manual.html The Installation manual is essential to a correct connection.
The Hookup Diagram can be downloaded from http://www.cytech.biz/hookup_diagram.html
 Current time is 08:08 pm
