When the doorbell (DP03) is pressed, the internal phones ring (RGR04 is needed) and the keypads chime.
You can record a message to play on the door station when the doorbell is pressed.
First create a Response
Reminder 7 On Keypad 0
This means play Reminder message 7 (16 Rreminders are available). "Keypad 0" means all keypads and door stations, but any specific keypad or Door station may be specified. The Response wizard screen is shown below
Next record a Reminder Message (7 in this example) in user menu 2,5 - enter 7# for reminder 7, then 4 for message, press 1 to record the message. Use an internal phone for better recording clarity. Press 2 to hear the recorded message.
This reminder should not be enabled on the Reminders screen as you do not want the reminder to play at a scheduled time.
In Event > Miscellaneous Events > select the Response that you have created.
Now test by pressing the Doorbell. The announcement should be heard on the doorbell/keypads
Instead of a reminder, the Say Words action can also be used. This plays words from
the word list instead of a recorded message
If you want the announcement to be heard on the telephone so that anybody using the phone can hear, go to Modules and Settings and check the biox "Hear Announcements on telephone". Note that this will cause all announcements to be heard on the phone momentarily (eg zone announcements)
Attachment: Reminder on KPDP small.jpg (Downloaded 144 times) Last edited on Saturday Mar 15th, 2008 03:30 am by slychiu
