Search by username
Demo Briefcase
 Moderated by: ndh, adlim
 New Topic   Reply   Print
Status:  Offline
 Posted: Saturday Sep 23rd, 2006 08:33 am
 Quote  Reply
The Demo briefcase shown here includes the KP04 LCD keypad, DP03 with Ringer, Scene Control switch, 2 x 9 watt lamps, 2 fans (representing airconditioning), 4 x two way conventional switches, RC01 remote control, and an optional KT01 monochrome touchscreen. a PIR and magnetic door contact is also included
This is mounted on a sturdy metallic flight case which hinges so that the equipment faces to the front.
A RJ45 connector allows other Comfort peripherals to be connected externally so it allows for easy expansion.
The DP03 is connected externally so that the full duplex intercom can be demonstrated with less feedback from the keypad
DEB02 is without KT01 and DEB02/KT is with the monochrome touchscreen
Attachment: briefcase_front2 small.jpg (Downloaded 38 times)
Status:  Offline
 Posted: Saturday Sep 23rd, 2006 08:35 am
 Quote  Reply
This is a view of the demo briefcase with the panel lying flat
Attachment: briefcase_flat small.jpg (Downloaded 39 times)
 Current time is 03:51 pm
