Comfigurator 3.1.8 Beta
 Posted: Saturday Jan 9th, 2010 06:13 am
Comfigurator 3.1.5 is available for testing as a beta version for testing (now 3.1.8, see  below in reply)
3.1.4 was an internal version for testing and was not released. 3.1.3 is still the current released stable version
The changes are
Bugs Fixed
  • Fixed situations where in Reading from Comfort I systems, an Exception may be encountered due to various incompatibilities.
  • "Connected as PABX Extension" flag dis not get written to Comfort when Selective Write is used. In this version, Selective write for PABX Extension wil automatically Reset Comfort
  • Import Responses does not  overwrite existing flags and counter names now.
  • Fixed - Configurator 2 files with CMS Account codes blank (0) caused exception when converted to Comfigurator 3 (.cclx)
  • Fixed -  Sunrise/Sunset Times> Daylight Savings times, if a city is not selected as location, and daylight saving is disabled, writing to Comfort will leave Daylight saving enabled, causing times to be incorrectly advanced by 1 hour. Workaround is always to select a city with the same time zone if Daylight saving is to be enabled.
  • Fixed Modules and Settings > Wordlists  changed to a non-English language, the Alarm Types Phrases are not matched to the language untill they are all assigned to the correct phrases in the language, resulting in the incorrect announcement and Display on the LCD of all Alarms
  • For UCM/KNX Configurator, Adding KNX to UCMs will result in correct write to Comfort so KNX actions will work. See problem described in the KNX forum topic for more information
  • RGR02/RGR03 checkbox is present for Comfort I File Systems
  • In Modules and Settings Description on Number of Door stations, Slaves  and SCS/RIo have been fixed
  • Response Wizard If Counters value allow 255. Previously only 0-254 allowed
New Features
  • Checking the LEM03 checkbox sets No of SEMs to 0 and setting No of SEMs >0 disables LEM03 checkbox as SEMs and LEM03 are mutually exclusive
  • Drag/Drop  works on Outputs just like Zones
  • Edit > Autogenerate Names works on Counters and Sensors. In Events> Counter, Edit Autogenerate Names causes the Counter names to have the same name as the assigned Response.  In Events> Sensor Responses, Edit Autogenerate Names causes the Sensor names to have the same name as the assigned Response. Note that Edit > Autogenerate also works on Responses and Zones individually.
  • In Responses, Edit > Delete Unreferenced Responses (ie shown in Black instead of blue) allows removal of  unused responses to make it easier to navigate.
  • In Modules and Settings, when changing the number of UCMs, Keypads, SCS/RIO, Slaves, the Modules Tab (to the right of the Comfort Tab on the left pane) will show the added modules in the correct number, but assigned to a default Type eg KP04, UCM General.  However when reducing the number of modules in Modules and Settings, the items in the Modules Tab are not reduced. This must be done manually. It is best to make any changes to the numbers of modules in the Modules Tab rather than in Modules and Settings screen
  • Support for future Velbus Module  in Response Wizard (not implemented in UCM yet)
Known Bugs
  • Full Read from Comfort causes an Exception. Workaround is to do Read  Selective and check "Select All"
  • Scan for UCMs erases all the information from the KNX Confiugration
  • In an If/Then conditional action references a Do Response, and the name of the  referenced Response is changed, the original Response order of actions is changed
 Posted: Sunday Jan 17th, 2010 10:19 am
Known bugs found in 3.1.5
Known Bugs
  • Scan for UCMs erases all the information from the KNX Configration. Workaround: DO NOT Scan for devices after configuring Modules
 Posted: Thursday Mar 4th, 2010 01:35 am
Comfigurator 3.1.8 Beta is available for download from
http://www.cytech-technology.com/temp/software/Comfigurator3.1.8.zip
Bugs Fixed from 3.1.5
  • Full Read from Comfort caused an Exception.
  • Scan for UCMs erased all the information from the KNX Configration
  • In an If/Then conditional action references a Do Response, and the name of the  referenced Response is changed, the original Response order of actions was changed
  • Eliminated errors in reading some Comfort configuraions
New Features
  • Velbus Configurator complete
Known Bugs
  • Read from Comfort will not populate the Modules Tab. This is bug from older versions.
  • Reading from Comfort without "Keep Names" option will show "Invalid UCM Number" errors in Responses concerning any UCM/KNX, UCM/Cbus or other external UCMs.  However the Responses themselves will be correct even though the configuration does not know about the UCM numbers. Workaround is always to load the cclx file before reading and use the "Keep names" option
  • In KNX Configurator, Monitor Mode does not work if the UCM number 1 is blank. This happens if a UCM which is not ID1 is used to connect to Comfort to do Monitor mode, but there is no UCM with ID=1 in the system. Workaround is to ensure UCM with ID=1 is always present in the system
  • If any letter in a  Response Name is changed from Capital to lowercase or vice versa, a Duplicate Name Error results. This is an  bug from older versions
 Current time is 06:05 am
