Error when doing Read (Comfort to PC )
 Posted: Tuesday May 25th, 2010 02:15 pm
davids
Unhandled exception:
System.Exception: Error reading C:\Program Files (x86)\Cytech\Comfigurator 3\Config\vocust.cfg: No vocab entry found for English Residential
   at Comfort.Vocab.Initialize(Configuration configuration)
   at Comfort.Configuration.SetNonSerializedValues(SystemSettings systemSettings)
   at Comfort.Configuration.Initialize(SystemSettings systemSettings, Boolean optimizeResponses)
   at Comfort.Form1.uploadComfortPCToolStripMenuItem_Click(Object sender, EventArgs e)
   at System.Windows.Forms.ToolStripItem.RaiseEvent(Object key, EventArgs e)
   at System.Windows.Forms.ToolStripMenuItem.OnClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleClick(EventArgs e)
   at System.Windows.Forms.ToolStripItem.HandleMouseUp(MouseEventArgs e)
   at System.Windows.Forms.ToolStripItem.FireEventInteractive(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStripItem.FireEvent(EventArgs e, ToolStripItemEventType met)
   at System.Windows.Forms.ToolStrip.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.ToolStripDropDown.OnMouseUp(MouseEventArgs mea)
   at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
   at System.Windows.Forms.Control.WndProc(Message& m)
   at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
   at System.Windows.Forms.ToolStrip.WndProc(Message& m)
   at System.Windows.Forms.ToolStripDropDown.WndProc(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
   at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
   at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
'vocust.cfg' has just
>Custom WordList
00=Spanish Comfort I,cs-wl-sp.cfg,sentence_spa.cfg
 Posted: Tuesday May 25th, 2010 02:25 pm
Which version of Comfigurator are you using?
Many cases of this type of exceptions were fixed in the later versions of software
Please upgrade to the latest version currently 3.1.9, see http://www.comfortforums.com/forum20/1798.html
 Current time is 11:06 pm
