Comfigurator 3.11.6
 Posted: Saturday Jul 30th, 2016 01:11 pm
Known Bugs
  1. If Input does not work for Input > 64 to 96. This also applies for older versions
  2. Deg C /deg F in Comfiguration flags is incorrect
  3. Optimum when adding  UCM/KNX2 causes exception
  4. Read from KP06A or KP04A does not change the KP06A/KP04A settings  in Comfigurator
  5. IRIO IR codes do not refresh when new IR codes are learned. Refresh button is needed
  6. Default template def40.cctx for UCM/Logic is missing from the installation. Please do File > Update Defaults to update the set of  default templates.
  7. In Flags screen, if Check Status box is checked for a flag, the status is updated, but if the flag changes subsequently, the flag status in the centre pane is not updated until you go to another page and back, or uncheck and check the box (old bug)
  8. Export Scenario does not work. Selecting any items will cause an exception
Bugs Fixed
  1. Actions for UCM/KNX2 did not work
  2. Importing a Configuration Item from a file with a different file system causes exception (old bug)
  3. Known Bugs in HIO and IRIO have been fixed
New Features
  1. Support for 4 Partitions in Comfort (requires Comfort Firmware 7.110)
  2. In Security > Zones, each zone has new settings for Partition and EOL shunts. These are for future Comfort features
  3. Support for UCM/Logic in File > New
 Posted: Tuesday Aug 2nd, 2016 12:40 am
cc_uk
Partitions sounds great! Do you plan a post about that specifically to detail how it should be used?
 Posted: Tuesday Aug 2nd, 2016 06:36 am
Yes information about partitions is coming soon
 Posted: Friday Aug 5th, 2016 08:58 pm
strickers
+1 for Partitions! Does that mean I can arm the garage while the house is unarmed?
 Posted: Friday Aug 5th, 2016 09:14 pm
Oooh that sounds like a good idea.
 Posted: Saturday Aug 6th, 2016 05:32 am
Yes, or the other way round. As long as the house and garage have separate entrances
 Posted: Saturday Aug 6th, 2016 05:52 am
Comfigurator 3.11.6 is released
It supports the Partitions feature and new products IRIO, HIO, UCM/KNX2, UCM/Logic (some of which are not released yet)
Otherwise, everything else works as usual
 Posted: Saturday Aug 6th, 2016 12:52 pm
You've gone back in time; assume you mean 3.11.6.0 rather than 3.1.6!!  :0)
 Posted: Saturday Aug 6th, 2016 03:34 pm
corrected, thanks
Hopefully nobody got 3.1.6
 Posted: Sunday Aug 7th, 2016 06:12 am
Default template def40.cctx for UCM/Logic is missing from the installation. This can be fixed by File > Update Defaults to update the set of  default templates.
 Posted: Sunday Aug 7th, 2016 09:25 am
Information on Partitions can be found here
http://www.comfortforums.com/forum16/4491.html
 Posted: Saturday Sep 10th, 2016 06:19 pm
Ghyllwood
I have just noticed that the Flags do not all reset to 0 when the system has been reset. - has tis been changed recently?
 Posted: Sunday Sep 11th, 2016 06:00 am
13th Post
Flags are not cleared at reset. This was from Formware 7.036 back in 2013
It is not related to Comfigurator.
This is better because if you have flag states that had been set and cleared, it remains the same state after reset. (but power off will clear the flags)
 Posted: Tuesday Sep 20th, 2016 04:05 pm
14th Post
Export Scenarios does not work with 3.11.6
It willl cause exception when you select the items to export
 Current time is 11:37 am
