Comfigurator 3.12.15
 Posted: Friday Aug 9th, 2019 02:22 am
Known Bugs
  • In Phone Numbers, when UCM/GSM4 is in the systrem, the Phone Permission checkboxes are missing for each user. They are enabled by default for all users
Bugs Fixed
  • KNX/Logic send text to id=01 (self) was invalid. This allows Status on bottom left to work
  • Divide action Parameters are fixed
  • In the Zones screen when the "Status " checkbox is checked to show the real time state of zones, when a zone state changes, the screen goes back to the top so higher numbered zones could not be seen easily. Now this has been improved so the zones screen does not jump when any zone state changes.
New Features/Changes
  • IRIO 0-10V  Dimmer Input switch added parameters "Direction" and "Quick Press" so that the switch can be used to dim up and dim down by long opress
  • IRIO analog outputs 0-10V added mapped on/off flag which turn off when the analog output value is 0 and turn on value is > 0. This flag controls an output which can be used to switch the analog output on or off
  • UCM/Cbus2 : When Imported from CBZ, the Register assignment is not  changed in Comfigurator if already mapped to Comfort Counter, Flag, Virtual Input etc. If a new Group address is imported, it is Unassigned (ie FF)
  • Register Monitor Window. This is a new window that allows selected Inputs, Outputs, Counters, Flags, and Sensors to be monitored for real time value. However, an issue is that  new file will also ask to log in, even when there is no register defined.
  • UCM/GSM4 added new 4G type 3 = 7600-LTE to support future LTE module
Download from http://www.cytech.biz/product_details.php?item_id=206
 Posted: Friday Aug 9th, 2019 02:53 am
Register Monitor
The new Register Monitor feature is very useful when you want to monitor a range of Comfort registers; Zones/Inputs, Outputs, Counters, Flags, and Sensors. Before this, you had to go to Zones to monitor zones, Outputs to monitor outputs, Counters to monitor counters, etc. This new feature allows all required registers to be monitored in a single window.
Go to Comfort Registers > Register Window.
The Login window appears. Enter a valid  user code.
A new window appears "Add Register to Monitor"
Select Counter, Flag, Output, Sensor or ZoneThen select the register number according to the register type selected
Continue adding registers to the monitor window.
The real time status of the Registers are shown
 Posted: Friday Aug 9th, 2019 11:49 am
Yes this looks really useful
 Posted: Friday Aug 9th, 2019 02:43 pm
3.12.15 downloads but I cannot get it to open
Basically I'm running Avast and it won't let suspicious objects through.
Running WIN 19 hopefully you can help
 Posted: Saturday Aug 10th, 2019 02:15 am
I am not sure how I can help. Try disabling the antivirus while you installl the software
 Posted: Saturday Aug 10th, 2019 02:17 am
What message does it give when it prevents the software from running? what virus does it detect?
 Posted: Sunday Aug 25th, 2019 08:47 am
Comfigurator 3.12.15 has been released. Please Upgrade
 Current time is 03:27 am
