The new version of Comfigurator 2.2.0 has been released. Please download from http://www.cytech-technology.com/temp/software/Comfigurator2.2.0_Single.zip
Please note that Engineer Code is required for download and upload. First, press F0 to enable Engineer code
The default Engineer Code is 6789
NOTE: PLEASE DOWNLOAD DEF31.CCT TEMPLATE FOR COMFORT II OPTIMUM (See attachment) AND REPLACE THE ONE INSTALLED BY COMFIGURATOR 2.2.0
Please review Known Issues below
HISTORY
V2.2.0 15/06/2007
Bug fixes- Fix problem with response compilation if response number = 255
- Fix problem with erroneous values in event log listing
- Save CCL values using English locale to avoid problem with comma as decimal point in Siren duration
- Limit counter value in IF statement to 254 to avoid erroneous end of response detection
- Fix incorrect values set for reminder message destinations
- Support user-entered branch actions
- Fix exception on incorrect user-entered action codes
New features - Hide ringer details for Comfort II
- Remove licensing checks
- Remove alpha pager
- Require engineer code for up/download. Press F0 on keypad to authorise
- Disable UCM concatenate if not CBUS
- Launch WizComfort
- Edit zones, zone types and alarm types using popup dialogs
- Right-click on zone type in zone popup to display/edit zone type
- Add descriptions and enable editing of tuning parameters for Comfort II
- Associate names with X10 transmitted codes (referenced within responses)
- Support UCM type Rako
- Support UCM type Lutron
- Support UCM as target for reminder messages
- Display some actions in more than one category in Response Wizard
- Support Sunrise/Sunset times
- Support firmware download
- Support unknown action codes
- Allow either IP address or hostname for network connection
Known Issues - Zone Types Screen sets Night Mode Settings to "Perimeter" and Sensitivity to 10
- Response Wizard - when sorted by Name, after adding a new Response, goes back to sort by Number
- Unable to save file with sensor register as feedback type.
- Saving file with a sensor register and then re-opening the file doesn't display the response.
- Program Crashes when double clicking on the right side of certain screens which have no fields eg Zones and Zone Types
- def31.cct installed by this program should be replaced by the new file def31.cct in the attachment to this post
Attachment: def31.cct (Downloaded 14 times) Last edited on Thursday Sep 6th, 2007 10:58 am by
