Getting this when I open my CCL file in Comfigurator 2.2.0. Tried everything to get rid of them but to no avail.
How can I get rid off these?
C:\Program Files\Cytech\Comfigurator\NewFuturehome.ccl(6653) :
Value for 'Number' outside range 1-1024
C:\Program Files\Cytech\Comfigurator\NewFuturehome.ccl(6658) :
C:\Program Files\Cytech\Comfigurator\NewFuturehome.ccl(6663) :
C:\Program Files\Cytech\Comfigurator\NewFuturehome.ccl(6668) :
C:\Program Files\Cytech\Comfigurator\NewFuturehome.ccl(6673) :
C:\Program Files\Cytech\Comfigurator\NewFuturehome.ccl(6678) :
C:\Program Files\Cytech\Comfigurator\NewFuturehome.ccl(6683) :
C:\Program Files\Cytech\Comfigurator\NewFuturehome.ccl(6688) :
C:\Program Files\Cytech\Comfigurator\NewFuturehome.ccl(6693) :
C:\Program Files\Cytech\Comfigurator\NewFuturehome.ccl(6698) :
C:\Program Files\Cytech\Comfigurator\NewFuturehome.ccl(6703) :
C:\Program Files\Cytech\Comfigurator\NewFuturehome.ccl(6708) :
Yes I checked the CCL file and there are loads in there (> 1090 responses!)
I started again with a blank CCL file and cut and paste between the broken and new file and now I'm up and working again.
Importing responses saved a bit of time. Would be nice to be able to import/export Control menu too.
I have the broken CCL file if you want to see it but I guess it was down to doing an upload from comfort into comfigurator that broke it.
Incidentally the "monitor value" feature on the control menu seems flaky! I was using it to look at counters for Smartfit interface; some times it works but mostly it doesn't. Counters are displaying OK in Wizcomfort and when I request via the keypad.
Is there an easy way to see the values in all of the counters. Would be handy for debugging.
