Click on SETUP at the top of the screen and OPTIONS
This is where you select whether Wizcomfort connects by a serial port (UCM/IR) or TCP/Ip (UCM/Ethernet)
If serial is selected, choose the Port 1 to 16
If TCP is the connection method, enter the IP address and the port for the UCM/Ethernet
In the box BIND TO THIS IP ADDRESS, enter 0.0.0.0
The Master Security Code is the user code that will be used to login automatically
Attachment: wizoptions.jpg (Downloaded 84 times) Last edited on Thursday Sep 6th, 2007 10:41 am by
