I thought i would share this idea for the use of a redundant tamper switch inside the comfort panel. As I don't use the tamper switch in my panel as I am constantly in and out of it and I was tired of using a torch to see inside all the time I decided to rig up a led strip light inside the panel. Initially I tried to use the switch but it breaks the circuit when panel is open and unless you wire it into a zone and then use output it cant really be used.
Where the switch was i replaced it with a 19mm push on/off switch which a I bought from ebay along with some self adhesive led strip lights the total came to around £10. so not exactly expensive.
Things you should look out for though:
Depth of switch (so as not to hit other components)
12V supply (I did not use the comfort supply for lights)
Attachment: 20150221_125907.jpg (Downloaded 22 times) Last edited on Sunday Feb 22nd, 2015 01:08 pm by Swiss-Toni
