Occupancy Sensor
 Posted: Thursday Feb 28th, 2008 11:49 am
dcrera
I want to control some lights using an occupancy sensor.
Questions :
1. Is there difference between an occupancy sensor and a PIR ?
2. If there is,  can a PIR be used ?
3. Can I connect the sensor to the input on the RIO to trigger responses (not alerts)
 Posted: Thursday Feb 28th, 2008 02:41 pm
TheMax74
1) I think yes, generally speaking, occupancy sensors "senses" occupancy instead of translated movement. They are more "sensible".
 X10 wireless PIR's, for example, offers ON status when a movement is detected and OFF status when a movement is not detected for a selectable amount of time.
Security wireless PIR's, like "Visionic", for example, have a battery saver system and, for many reasons, are not suitable for occupany sensors.
2) Yes, i use x10 wireless PIR's (suitables as occupancy sensors), but you can use any type of wired PIR (in this case, you need to manually program a retarded response that switch off your light, because PIR's generally doesn't send OFF status) .
3) I don't know, sorry.
 Posted: Friday Feb 29th, 2008 12:06 am
The answer to (3) is yes. RIO inputs do trigger ON and OFF Responses
 Current time is 03:58 am
