UCM ID change
 Posted: Saturday Mar 15th, 2025 05:55 pm
Ghyllwood
Does anyone know how you change the ID of this UCM I think it is  ETHge V2.2.3Or can you point me at the relevant manual? Thanks
Attachment: UCM.jpg (Downloaded 13 times)
 Posted: Sunday Mar 16th, 2025 01:38 am
The Old UCM ID shunts are SW7 marked RS485 promary. All are shunted in the photo so the ID is 1. Check that the Red and Green D9 and D10 leds are blinkin to show the UCM is beng polled and is replying
 Posted: Sunday Mar 16th, 2025 11:57 am
Ghyllwood
Thanks Chiu, I remember the old touch screen was a  modified CBUS UCM, so wanted to check the network UCM had the correct ID. And yes, the red and green lights are blinking slowly.
First of all, I updated the Configurator to V3.14.14.0 I have spent nearly 2 days and no nearer a solution. The Network UCM can be accessed from the computer, but it is not talking to Comfort; it just says failed to connect to UCM. The UCM doesn't communicate at all, to update the date and time either.
This all started when I removed a redundant KT03 touch screen keypad. I updated comfort several times with  very small changes and then it just stopped communicating with anything; system information time update, etc.
Then I noticed the Fermax door release was permanently on and buzzing, so I have removed the DM02 from the system. But it will still not communicate.
Initially it said communication failure Keypad 1, which was the one I removed, so I changed the Keypad ID of No6 to No 1 and the keypads are all saying failed to connect to Keypad No 6, which is expected, as Comfort thinks there are 6, until I upload the modified file. So the keypads and UCM's are all talking internally, but I cant update the Comfort main board from the computer.
I have exhausted all sense of logic now and going around in circles, Can you think of what to test next to get the UCM talking to the Comfort main board?Thanks
Attachment: Comfort.jpg (Downloaded 11 times)
 Posted: Monday Mar 17th, 2025 01:31 am
Your comfort server manager shows 2 IP addresses but you have only 1 ucm. where is the other ETH03? Can you try to connect to the 2nd IP address?
 Posted: Monday Mar 17th, 2025 05:41 pm
Ghyllwood
The other IP address, with a separate ETH3 is for the office and workshop and it has its own separate UCM, which I can connect to that one fine. Its the main house UCM which does not communicate. Perhaps I should remove the working  UCM and try it on the house. The data bus is working in the house, as It talks to the RIO's, keypads etc. but not talking to the UCM and it does not update the time anymore.
 Posted: Tuesday Mar 18th, 2025 12:51 am
yes it is a food idea to swap the ucms to identify the issue
 Posted: Saturday Mar 22nd, 2025 08:04 pm
Ghyllwood
Thank you for your help - I swapped the UCM/ETH03  from the other system and it worked, so I need to order a replacement
 Posted: Saturday Mar 22nd, 2025 08:11 pm
Ghyllwood
Can the UCM be ordered without the ETH03 plugin sub-module? I know that is working, as I could log into it, from the outside.
 Posted: Sunday Mar 23rd, 2025 01:21 am
Yes you can order UCM06A if it is in stock with Laser. You should check with them as they have an order with us to be shipped soon
 Current time is 10:05 pm
