Changes to Part Numbers
 Posted: Sunday Mar 14th, 2010 10:01 am
Please note the following changes to Cytech Part numbers effective immediately
UCM05 renamed UCM/232
UCM05  is renamed UCM/232 UCM with serial interface
UCM/USB
UCM with USB interface has been available for some time for those who are not aware.
UCM/Audio
This part number shall be removed because the audio function can be used for UCM/232, UCM/USB and UCM/Ethernet. Order AUD01 plug in board for any of these 3 modules to provide the audio function.
UCM06
This is the baseboard for the UCM/232, UCM/USB and UCM/Ethernet.
Adding RS232/PB to UCM06 becomes UCM/232.
Adding USB01 to UCM06 becomes UCM/USB
Adding ETH01 to UCM06 becomes UCM/Ethernet
Of course UCM/232, UCM/USB and UCM/Ethernet can also be ordered.
IRR01-05, IR01W-05, IRM01-05, CSM03PCB-05, CSM03CT-05, ZTS01-08, LP01-08
These multiple pack products have been removed due to feedback from customers that they are inflexible and do not allow other quanities to be ordered. They can be ordered in any quanitity of single units using part numbers IRR01, IR01W, IRM01, CSM03-PCB, CSM03-CT, ZTS01, LP01. The products will be packed in either plastic bags or small cardboard cartons  with the part number and quantity indicated on the label.
 Current time is 11:04 pm
