X10 Two WayDevice Status
 Moderated by: adlim
 Posted: Friday Feb 20th, 2015 01:48 am
jjsg
Hello;
Who to read the status of one x10 Module( two way module)
an take actions according the read code.
According the link:http://www.homeseer.com/support/homeseer/WebHelp2/scripting/devices/scripting_devices_devicestatus.htm
One X10 device can ansewer with the following codes:
2 = ON
3 = OFF
4 = DIM
17 = UNKNOWN
So who implement the following code in Comfort:
If X10 B1 = ON Then
    X10 A8 On
End If
If X10 B1 = OFF Then
    X10 A9  On
End If
BR:José Gonçalves
 Posted: Friday Feb 20th, 2015 11:11 am
Go to Events > X10 Receive Codes, select the X10 signal eg B1 and program the On Response and Off Response
 Posted: Friday Feb 20th, 2015 11:45 pm
jjsg
Hello;
Your solution don't works if manually operate the X10 Module, so the only way
is request the satus of the module. Using the x10 Function's:
->Status request
->Status on
->Status off
But I don't know who implement that.
See atached picture.
BR:JG
Attachment: Status request 2015-02-20_192353.jpg (Downloaded 17 times)
 Posted: Saturday Feb 21st, 2015 06:12 am
A Status Request should cause the device to send its status via X10 Staytus On and off
But from what I remember, most X10 devices do not support the X10 Request command
If you need status, X10 is not a good solution, and anyway it is obsolete. Can you still buy it?
The closest product would be Z-wave which is supported by a UCM/Zwave
 Posted: Saturday Feb 21st, 2015 07:45 pm
jjsg
Hello;
The following modules do not support X10 request Command:
-> LD11 - Lamp-/dimmer module, DIN rail mounting (ON/OFF/DIM)
-> AD11 - Appliance module, DIN rail mounting, on / off (230V, 16A)
-> SW10 - Shutter switch, in-wall
But following modules they support X10 request Command:
-> LWM1P – micromodule lamp module (on/off/dim/bright), max 250W
-> AWM2P – micromodule on / off (230V, 16A)
-> SWM1P – shutter micromodule (up/down/dim/bright)
I installed confort and X10 in 2003 in my house, and it's not perfect but for the price it works well, so i don't have plans to change it.
If i can buy it ? Yes i can buy:
http://www.haibrain.com/domotics-haibrain-previously-marmitek-c-131_49.html
http://bmbelectronics.eu/products.php?id=1&resourceid=2
http://www.eurox10.com/Products/Micromodules.htm
If I will change/upgrade some in the future will be for the universal protocol KNX.
So for the moment for use  with LWM1P I want implement the following code :
X10 A7 StatusRequest
 If X10 A7 StatusOn Then
    X10 A8 On
End If
If X10 A7 StatusOff Then
    X10 A9  On
End If
Can you help me?
For that remember , according the link:
2 = ON
3 = OFF
4 = DIM
17 = UNKNOWN
BR:JG
 Posted: Sunday Feb 22nd, 2015 07:28 am
When the x10 support was first introduced in Comfort in 2000 there were no X10 modules able to send the X10 status
So I am afraid comfort does not read the x10 status replies, and it is not expected that we will add more functionality to X10 now
 Current time is 01:23 pm
