New Companion Touchscreen compatibilty
 Moderated by: ndh
 Posted: Wednesday Aug 12th, 2009 01:00 pm
WMADKOUR
Hello ,
as you might know the convergent Companion touchscreen been upgraded with the new BORG http://www.borgdisplays.com/ with NEO line that runing companion operating system.
my Question is. i have a client who need to install two touch screen color with his system, and he refused to install any keypad.
Dose the system accept two touch screen? we figure that we could install one using UCM /audio (10mt closed to system to use audio) and the other using ethernet, is this applicable?
could we eliminate keypads from the systems?
thanks for feeding me back.
 Posted: Wednesday Aug 12th, 2009 01:33 pm
You can use two touchscreens connected to UCMs, as up to 8 ucms can be connected to a system
We are devloping the new version of Wizcomfort which wil run on Touchscreens with XP, which wil be ready in aboout 3 months
Borg may be a good choice of wall mounted touchscreens, which Wizcomfort may run on. I would not use Companion Neo though as support was through Convergent Living which is no longer operating\
 Posted: Wednesday Aug 12th, 2009 01:41 pm
You must have 1 keypad in the house even if it is inside a room. You cannot depend on touchscreens They look nice but if there is a power failure then the whole system cannot be used
For software and touchscreens, look at http://www.quiiq.com/
They have a Comfort interface using a UCM
 Posted: Wednesday Aug 12th, 2009 03:16 pm
WMADKOUR
with my last contact 2 weeks ago with Mr. Craig Slawson (BORG, ex-convergent) i was informed with the following "We offer integrated control solutions with Companion NEO supporting a host of systems drivers like that for Cytech and others attached.  Very easy setup.  All self-contained.
which means that his new touchscrean Companion OS is support by BORG, dose it operate smoothly with cytech
i can not found the site you mentioned of touch screen, since this project will be signed within days and we have to order according ASAP
 Posted: Wednesday Aug 12th, 2009 06:36 pm
Advanced Member
Hi Chiu
That link seems to go to a web hosting site?
 Posted: Thursday Aug 13th, 2009 01:58 am
strange, if you type http://www.quiiq.com it goes to the correct website
 Posted: Friday Aug 14th, 2009 07:32 am
TheMax74
slychiu ha scritto: You must have 1 keypad in the house even if it is inside a room. You cannot depend on touchscreens They look nice but if there is a power failure then the whole system cannot be used
The link is wrong. While text displays two "i" in the domain name, the link point at http://www.quiq.com, with one "i".
 Posted: Friday Aug 14th, 2009 07:53 am
The lesson here is not to use 2 i's in a domain name, I guess
 Current time is 05:45 am
