Search by username
Using a Meteor CID with Comfort
 New Topic   Reply   Print
nigelgiddings
Status:  Offline
 Posted: Monday May 12th, 2008 03:20 pm
 Quote  Reply
I have recently connected the Tel IN and Tel OUT connections of my Comfort system in line with the outside line.
I also have a Meteor CID device which I use in conjunction with the xAPTel application which has worked very well up until now.
It now looks as if I connect the Meteor on the Tel IN side of the connection it does not work properly, If I connect it on the Tel OUT side it seems OK. See below:
Line -- ADSL Filter -- Meteor -- Tel IN Tel OUT -- PBX (Meteor does not work)
Line -- ADSL Filter -- Tel IN Tel OUT -- Meteor -- PBX (Meteor does Work)
NB the Meteor is not strictly 'in-line' it is 'T-ed' accross the line at the point shown.
While the Meteor would capture all incoming calls irespective of position I was hoping to monitor outgoing calls made by Comfort (The Meteor monitors both i/c and o/g calls).
I wonder if there is anything between the Tel IN and Tel OUT connections that might interfere with the device? Has anyone else experienced similar?
TIA
Nigel
Status:  Offline
 Posted: Tuesday May 13th, 2008 02:09 am
 Quote  Reply
Not familiar with Meteor but I cannot see any reason why it would not work on TEL IN. TEL IN is connected to TEL OUT via a normally closed relay so there is nothing between them when comfort is not dialing out or beaing accessed remotely
 Current time is 03:05 am
