Search by username
Curtains buttons in 2 modes
 New Topic   Reply   Print
mindi65
Status:  Offline
 Posted: Friday Jul 4th, 2008 03:35 pm
 Quote  Reply
I have 2 buttons connected to 2 RIO inputs and 2 relays connected to mainboard outputs for UP and DOWN of curtains. When one relays is on then curtains are going to one direction when another - to another direction
I need to create set of responses to operate it in following way:
Introduce a delay (like 1 second) to each of the "down" and "up" button. So when you press "down" and then you want to cancel it by pressing "up", you can do so by turning off output for curtain down and after 1 second turning on output for curtain up. The same principle works from "up" and "down".
If you just press "up" or "down" and hold more then for 1 second then one relay is ON for measured time.
Mindaugas
hendy
Super Moderator
Status:  Offline
 Posted: Monday Jul 7th, 2008 08:54 am
 Quote  Reply
One way to do it is like the following:
Assuming the 2 buttons are connected to input 1 (Up button) and input 2 (Down button) of RIO ID 1 and relays are connected to output 1 (controlling curtain up) and output 2 (controlling curtain down) of mainboard; open Comfigurator > Events > SCS/RIO Response:
Put the following response at the "On Response" of ScsRioResp129 (UP button):
    Output Output02 Off
    Do Output1ON [Output 1 ON] After 1 Second Using Timer01
At the "Off Response" of ScsRioResp129:
    Output Output01 Off
Similar thing for "On Response" of ScsRioResp130 (DOWN button):
Output Output01 Off
    Do Output2ON [Output 2 ON] After 1 Second Using Timer02
And at the "Off Response" of ScsRioResp130:
    Output Output02 Off
In a normally open switch/button, the "On Response" is triggered when the button is pressed (close contact) and "Off Response" is executed when the button is released (open contact).
Hope it answers your question.
mindi65
Status:  Offline
 Posted: Monday Jul 7th, 2008 06:56 pm
 Quote  Reply
 Current time is 08:25 am
