| Author | Post |
tomekajja Member
Posted: Friday Nov 21st, 2008 12:09 am |
Can UCMO5 (version 5.156) be used to download the word list to KP04? The manual says UCM01 (version 5.72 and above).
I need to do this because the KP04 shows wrong words for the zone activations.
I am using a Comfort I board with firmware ULTRA 4.230.
Also when down loading the word list using the "LCD Keypad Language customization software", the instruction say disconnect the KA/KB from the main board J15 and connect the UCM KA/KB to Keypad KA/KB.
Does this mean I power the Keypad and UCM and connect the keypad KA/KB directly to the UCM KA/KB and then download the software?
Tom
slychiu Administrator
| Posts: | 1048 |
| Status: |
Posted: Friday Nov 21st, 2008 08:04 am |
Yes the UCM05 is an advanced version and a replacement for UCM01 so it can be used for this purpsoe
You are correct, power the keypad and UCM using the existing wires and disconnect KA/KB from the Comfort and connect it between UCM and keypad to do the download
It is not a simple procedure. Consider upgrading to Comfort II by buying a Comfort II PCB only. This will allow you to benefit form all the new features and those to come
tomekajja Member
Posted: Friday Nov 21st, 2008 09:58 am |
I have followed procedure on the KP04 manual but I get login failure even if I use user or engineer code.
Please help
leonchue Administrator
| Posts: | 21 |
| Status: |
Posted: Monday Nov 24th, 2008 01:31 am |
I suspect that you did not have KA/KB connection to the main board. Please check that.
After signing in, then you will be prompted to disconnect KA/KB from main board
tomekajja Member
Posted: Monday Nov 24th, 2008 04:10 pm |
I think it tried this but will double check and try again.
Tom
 Current time is 03:00 am | |
