If you bought the UCM/Ulti, it should look like the attached photo with the daughterboard plugged into the UCM baseboard. We do not supply the product as a separate UCM and Daughterboard, it should be as a complete UCM/Ulti assembled and tested
Your pictures labelled frontside and backside are of the Ulti daughterboard which plugs into the base UCM board
The picture labelled Daughterboard is actually MinderPro
Please check with Clipsal or your supplier, as someone seems to have give you the wrong parts
Attachment: 100_0856 small.jpg (Downloaded 17 times) Last edited on Wednesday Dec 24th, 2008 10:42 am by admin
