Search by username
UCM05 / ETH01
 Moderated by: slychiu, adlim
 New Topic   Reply   Print
Damon
Status:  Offline
 Posted: Friday May 30th, 2008 08:14 pm
 Quote  Reply
Any help with this problem on Ultra II new system
Comfigurator = 2.2.3 / UCM = 5.159
I have been using a UCM/ETH with no problems on this system as a temporary measure until my UCM05 came as it was out of stock.
I keep getting the error message "Unknown exception while connecting to UCM" .
So Far
1- I have used the DS manager to set the IP and it can see the ETH01
2- I have tried using the RS232 on the UCM05 and when removing link F and jumper to RS232 it works, which make me think the UCM05 is OK
3- I have tried a new ETH01 and still the same problem
4- I put the old UCM/ETH back in and it works fine without changing any settings
Damon
Status:  Offline
 Posted: Saturday May 31st, 2008 02:41 am
 Quote  Reply
Are the Device Server settings correct as shown on page 40 of the UCM Manual?
ie the serial baud rate, parity etc. Set Flow Control to NONE
The Eth01 settings are held in the ETH module so the two that you use would have diferent settings
Also on the UCM, remove the SW8-H shunt to disable Flow Control
Use Hyperterminal (Private Edition 6.3 is better) to set up a connection to the UCM/ETH and see uf you can log in by typing <CTRL-C>LI1234<ENTER>. UDCM should reply <CTRL-C>LI01
1234 is the user code so if you have changed it use the new code
Damon
Status:  Offline
 Posted: Saturday May 31st, 2008 09:06 am
 Quote  Reply
Thanks i should read the manual next time 3 settings were wrong
1- it was set to UDP and should have been TCP
2- baud rate was 38400 and should be 9600
3- and flow was on and should be off
up and runing now
 Current time is 10:04 pm
