Search by username
RS232 Cable
 Moderated by: slychiu, adlim
 New Topic   Reply   Print
bod
Status:  Offline
 Posted: Thursday Aug 10th, 2006 07:47 am
 Quote  Reply
I want to patch the rs232 cable through cat5 cabling.  However the rs232 cable has 9 pins (and cat5 only has 8 pins).
Are all the pins needed for comfort, or can i miss one out?
adlim
Status:  Offline
 Posted: Thursday Aug 10th, 2006 08:27 am
 Quote  Reply
Basically, Comfort only needs to make use of 3 pins:
Pins 2, 3, and 5.
Warby
Status:  Offline
 Posted: Wednesday May 7th, 2008 11:15 am
 Quote  Reply
Are pins 2,3 crossed over or straight thru? 2-2,3-3 or 2-3,3-2
Status:  Offline
 Posted: Wednesday May 7th, 2008 11:59 am
 Quote  Reply
It depends on what it is connecting to. The UCM cable has one male and 1 female at the ends. In this cable, the connections are straight through 2-2, 3-3, 5-5.  The male connector is plugged into the UCM and the female end into the PC
If you are connecting the UCM to a serial interface of another device with a connector which is the same sex as the UCM ie Female, then you  need a Male to Male serial cable, and in the cable you would need to cross 2 and 3, ie 2 - 3 and 3 - 2, while 5 remains connected to 5 (common)
 Current time is 08:24 am
