Comfort Home Automation/ Security System Forums > Products > UCM > UCM/USB - Driver Installation Instructions
 Posted: Monday Jun 8th, 2009 12:48 pm
muddymickey
I fitted my UCM/USB board last night, and when I connected up to my laptop (running Windows 2000 Professional, SP4), I was prompted to install drivers for the USB UART device ?
There don't appear to be any suitable drivers with my Windows install - so can you tell me where to download suitable drivers from ?
Many thanks
Lee
 Posted: Monday Jun 8th, 2009 01:22 pm
The drivers for USB are provided but not automatically installed as a user may have the drivers already installed already
When the software asks you for drivers, select the installation folder for Comfigurator3 which is normally C:/Program FilesCytech/Comfigurator 3/USB Drivers
Note that out of date preinstalled USB drivers are the main cause of not being able to communicate with the UCM/USB
Instructions for updating the USB driver are found in http://www.comfortforums.com/view_topic.php?id=2431&forum_id=73
 Posted: Monday Jun 8th, 2009 01:25 pm
muddymickey
Thanks - will try it tonight.
 Posted: Thursday Nov 5th, 2009 07:19 am
The instructions for installation of the USB drivers under various operating systems can be found below
Windows XP
Vista
Windows 7
If required, the USB Drivers can be found in the USB Drivers folder in the Comfigurator program folder, eg Program FilesCytechComfigurator 3USB Drivers
The new version of the USB Drivers which is compatible with Windows 7 as well as XP and Vista can be downloaded from here
The UCM Manual has also been updated
Problems with the UCM/USB not able to communicate with the PC are normally due to an outdated USB driver which has been installed previously. See forum topic at http://www.comfortforums.com/view_topic.php?id=2431&forum_id=73
 Posted: Monday May 3rd, 2010 01:51 pm
Please note that if you have a UCM05 or UCM/232 and connect it to a USB port of your computer, you should select in Comfigurator, Settings > UCM Interface as Serial and NOT USB
Look for the COM port assigned to your serial to USB convertor in Windows Control Panel > System > Hardware < Device Manager
Enter the COM port for the connection
The Comfigurator USB interface is only for the UCM/USB which has a built in USB interface
 Current time is 10:14 pm
