Search by username
Comfort Home Automation/ Security System Forums > Comfort > UCM > Recording Audio via UCMAudio to Comfort - HOW !?
 Moderated by: slychiu, adlim
 New Topic   Reply   Print
palmlodge
Status:  Offline
 Posted: Wednesday Oct 31st, 2007 10:27 am
 Quote  Reply
Put simply, how can you get an audio feed from a PC (ie a pre-recorded item) into Comfort as a Reminder Message
Not by using a Keypad Mic.
I did try to look at getting the PC to just play a stream via the UCMAUDIO to the doorstation but that appears to be impossible.
Thnx
palmlodge
Status:  Offline
 Posted: Monday Nov 12th, 2007 09:13 am
 Quote  Reply
bump
palmlodge
Status:  Offline
 Posted: Thursday Nov 29th, 2007 06:50 am
 Quote  Reply
Bump
garym999
Status:  Offline
 Posted: Thursday Nov 29th, 2007 07:43 am
 Quote  Reply
Use WizComfort...
Connect PC to UCM Audio both sound wise and data wise, then using WizComfort you can use the SW keypad just like you would the real one to access and record the reminders. Just hit play on the sound file after the beep and # at the end.
 Current time is 10:12 pm
