Heatmiser UCM; can I use ETH03 rather than ETH02
 Posted: Friday Aug 1st, 2014 01:21 am
MDKKEN
When buying heatmiser UCM; the documentation states RS485 or Ethernet.
Does this mean
  1. Either Universal UCM + RS485 or
  2. UCM06 + ETH02 or
  3. UCM06 + ETH03
Are all three supported?
  1. I have ETH02 currently. can I replace plugin ETH02 with ETH03 on UCM06 so i get extra features of ETH03 plus still  heatmiser if using ethernet?
  2. Also if UCM  + RS485, then I do not need netmonitor?
Any help to remove confusion with greatly appreciated.
 Posted: Friday Aug 1st, 2014 06:36 am
For wifi heatmisers, you need
UCM/Heatmiser + ETH02 or UCM/Heatmiser+ETH03 can be used for Heatmiser wifi modules, not UCM06 which is for Comfigurator and ios/android apps
However we sell only ETH03 now as it replaces ETH02
For rs485 heatmisers you need UCM/Heatmiser with RS485 interface. You do not need the netmonitor. You need the UH1 for connection to the heatmisers and ucm/heatmiser
I dont think the documentation mentions Universal UCM or UCM06 (unless there has been a mistake)
The UCM/Heatmiser has dedicated firmware to manage the heatmiser communications
UCM/Universal is meant for communications with many 3rd party products but it is not able to handle the Heatmiser because of the complexity of its protocol
UCM06 is the baseboard of the  general UCM. If you plug in the ETH03 it is the same as UCM/ETH03. If you plug in the USB01 interface it is the same as UCM/USB
I hope that clears up the confusion
 Current time is 05:04 pm
