Read Eeprom
 Posted: Saturday Mar 28th, 2015 07:00 pm
If I do a HM learn on my HM WiFi  it reads the eeprom and I can map counters and flags etc. I can write back these changes to the eeprom and at runtime all looks to be OK and I can see values changing (in my Object Matrix BTW!! :0)).
What is confusing me though is that if I re-read the eeprom then the configuration returned is blank in comfigurator. Surely this isn't correct behaviour?
I'm using latest firmware's for HM/Eth3 and comfigurator.
 Posted: Sunday Mar 29th, 2015 07:55 am
That cannot be correct
When you  learn, comfigurator is giving a read from eeprom command as well
Can you send the IO Monitor when read gives a blank result?
 Posted: Monday Mar 30th, 2015 04:47 pm
Thanks, this seems to be a problem withComfigurator from 3.7.6 onwards
 Posted: Monday Mar 30th, 2015 09:26 pm
Quite possibly as I haven't done a HM learn for a few versions now.
When do you think a fix will be available?
J
 Posted: Tuesday Mar 31st, 2015 06:53 am
We found that this is due to a difference in handling between the heatmiser firmware after 7.035 and Comfigurator after 3.7.6
The Heatmiser module data is obtained by learning and it is read only so never changes except by learning
When Comfigurator after 3.7.6 writes to EEPROM it does a global Erase of the EEPROM before writing the mapping data so it erases the module data (DCBs) as well
Only the mapping data is used by the UCM/HM and the module data is for information only
Read from EEPROM thus causes the modules tab to be blank
The solution I propose is to remove the Read from EEPROM button so that if you need to refresh the modules tab, just do a Learn again. Read from EEPROM does not realy have much use
 Posted: Tuesday Mar 31st, 2015 10:19 am
How is this different from ZWave as this also has module info that is "learned" and doesn't change unless you do a learn again.  Here I can happily still Read from Eeprom and write back without issues so cant you use the same method?
Personally I'd rather the Read worked as I find the Learn pretty flaky at times and you may have to do 2 or 3 times before it fetches the config correctly from HM.
 Posted: Tuesday Mar 31st, 2015 02:38 pm
I agree with Julian on the Read/Learn issue. I tested both my ZWave and Universal and they worked fine.
 Posted: Tuesday Mar 31st, 2015 03:33 pm
The difference is that zwave and universal have only the one mapping tab which is read/write. When you write to EEPROM, the whoiiole table is written to EEPROM and read from eeprom reads it back
Heatmiser has another modules tab which is read only, and is for information only. Write to EEPROM erases this tab
Do you have the need for a separate  Read from EEPROM button when the Learn button does exactly the same thing?
 Posted: Tuesday Mar 31st, 2015 08:58 pm
Unless I'm missing something, Learn and Read-Eeprom are meant to be different functions.
LEARN - Interrogate the Heatmiser Thermostat to get the config, store this in the Eeprom and read the Eeprom into Comfigurator.
READ Eeprom - Fetch the previous config into Comfigurator without re-interrogating the HM Thermostat (This can be the flaky bit requiring a few attempts IMHO)
 Posted: Wednesday Apr 1st, 2015 06:27 am
Learn obtains the Module information from the Heatmiser modules and "reads from eeprom" into the Heatmiser tab.
Read from EEPROM just reads from EEPROM
Hence Learn encompasses all the REA from EEPROM functions so you are not losing out n anything
 Posted: Wednesday Apr 1st, 2015 08:42 am
LEARN will need to be improved then as way too flaky at the moment; it takes 2 or 3 attempts before it grabs the config from the thermostat in my setup. Its a case of press learn, wait for it to read the eeprom and then check the tab to see if the thermostat module is found. If not i have to try learn again until it does.
 Current time is 04:16 am
