KT01 Display Problem
 Posted: Tuesday Aug 15th, 2006 02:22 am
adlim
Check to see if font smoothing is enabled on the PC, if so, uncheck the box and redownload the file to the KT01.
Font smoothing is in "Display Properties -> Appearance ->Effects", uncheck the option "Use the following method to smooth edges of screen fonts".
Once you've done this just download the file to the screen again - no need to change anything on the screen set up.
Attachment: display.JPG (Downloaded 24 times)
 Current time is 04:24 am
